I have a 1JZ in my BMW e36 M3, my stock twins are smoking and are starting to boost less and less. You know what that means? Single turbo time!:naughty:
I needed some input on 2 turbos that i have narrowed it down to.
The first is a Precision 6262 .84 divided housing journal bearing. i would be buying brand new, for 900 shipped. It seems to be favorite round these parts.
The second choice is a used Turbonetics 62-1 single ball bearing non divided .63 ar non divided housing. Here is what the seller posted about it :
Hey here is my turbonetics 62-1 t3 .63 ballbearing for sale. I bough this turbo brand new about two years ago for $1300 and never had any problems is oil feed.it comes with oil fitting adapter and a 2.5 aluminum elbow already welded in you just need the fitting.it have a normal shaft play, never smoke, you also can buy a t4 housing. made 360hp at 24 psi in my sr20det only driven on summers no winters. turbo is good for 600hp, selling it because i just got a bigger turbo. located in mn,pm me for any question
im looking for $650 obo shipped on the lower 48
so that would be 650 for a BB that in theory would spool a bit faster. Honestly i've never ran a turbonetics or heard of someone running them since the early 2000's when BB's were first coming out and garrett kinda took off. i could probably upgrade the BB to a triple BB, or i could just go with the 6262.
my goals are 400-450WHP with a Lightning quick spool because my car's primary use is Drifting. so what do you say? Older used single BB turbonetics t3 .63ar for 600 or new .84 divided t4 journal bearing precision 6262 for 900?
