Hi,
I am using a Supra turbo (93) on my V6 MR2. In my first build, I used a restriction in the oil feed, with a 0.060" diameter hole to diminish oil pressure.
After rebuilding, I removed that restriction.
In less than 1,000 miles, I have oil going trough and a turbo rattling noise when spinning down.
It was my first turbo rebuilt, and I believe that is what caused the premature failure, not excessive oil pressure.
I am tempted to replace the turbo instead of rebuilding it again.
If I do rebuild, do I need or not a restriction on the oil feed?
