i am looking to find a metric 12mm X 1.25 to an -4 fitting and i cannot find one anywhere. does anyone know where i can get one? or is there another way to hook up an -4 to the stock 7m turbo oil feed hole? thanks
3.0 GT;1531105 said:i am looking to find a metric 12mm X 1.25 to an -4 fitting and i cannot find one anywhere. does anyone know where i can get one? or is there another way to hook up an -4 to the stock 7m turbo oil feed hole? thanks
nosechunks;1531131 said:http://store.driftmotion.com/static/i-1jz2jz7moiloutletadapterfitting.php Support Forum Vendors.
3.0 GT;1531137 said:ok wow im an idiot, didnt see those. thanks. and does anyone know if -4an without a restrictor would be fine on a holset turbo?
You'll be choking it with the intake.3.0 GT;1531231 said:i have the stock 7m oiling system but the oil pump is shimmed. the pcv system is set up like stock except new hoses. the intake will be a 4 inch to 3inch reducer then a short 3 inch pipe connecting the reducer to the stock accordian pipe with a lex afm and and 3 inch filter. i will be running a -4 an feed line with a -10 drain facing straight down. will that be good enough? if not what size restrictor would i need?
Holsets are journal bearing (for the most part) and can withstand up to 65psi of oil pressure I believe. The stock oiling system is "safe" (for the turbo, not safe for mod'd 7M's) because of the 40psi reliefs.nosechunks;1531548 said:Is the turbo ball bearing? IIRC ball bearing turbos are the ones that need restrictors.
kneedragger85;1531598 said:You'll be choking it with the intake.
I switched to a thermostat full flow for about a weeks time before rebuilding my engine. Cold idle saw 60-70psi on startup, I'm also wondering about a restrictor.
3.0 GT;1531644 said:ok, if im choking it with the stock accordian hose work becasue i still need to use the lex afm and it is 3 inch. i could just fab up a 4 inch pipe then a 4->3 inch adpater to fit the lex afm
Nghty89;1531710 said:I think you should ditch the afm setup altogether... : p
