I just got my wifes car from the shop today. They've had it for almost five months. I don't even make it out of the parking lot and the check engine light comes on. I didn't care, I was taking it home. When I get on the highway I give it a little throttle and the boost gauge goes from negative to about .5 ..........It's the stock gauge and I know it doesn't read in decimals but you get the idea. When I took the car to them I checked the stock blow off valve by blowing through it. The manual said if you can blow through it then it's broke. Is this why I'm not building boost? I have already bought a turboxs blowoff valve and intend on installing it this weekend. Could their be another reason the turbo won't build boost, or do you think that this will fix it? Thanks a lot............lol:1zhelp:
Edit: The reason the shop had it was to install a new motor. I used the turbo off of my 91, so I know it works good, but the stock blow off valve on her 89 is shot.
