Turbo my Na?
mattman
96
Michigan
there a guy in my local newspaper that has a 1987 turbo motor for like $250.
my motor is mostlikly in better condition cuz the motor was pulled and replaced all the wires and that good stuff. but im wondering if i should buy the motor and steal the turbo? also how much work and money will it take? if you got any input i would like to hear. thanks!
shaeff
Kurt is FTMFW x2!!!!
11
Around
mattman
96
Michigan
not sure i got to talk to the guy. my cousin works for toyota and can hook me up. Im sure he will do most of the work. he told me I will need to have the computer(duh) but also there a oil pan thingy that i will need. Im thinking to buy the motor and jsut rebuild it and drop it in my car.
shaeff
11
Around
there are lots of things that will nickel and dime you to death if you turbocharge your N/A block.
better off swapping motors. ;)
thechori
supra-deprived
Oct 3, 2006
567
houston
care to elaborate? i've got most of the parts to go turbo but i'd like to hear what nickel and dimed you
st2b
589
Versailles (Lex) Ky
You might as well take the time just swapping motors.
Here's why, when we did the na-t on my 5m Supra, here's what we had to go with, and it STILL blew.
1. Manifold and Turbo
2. Rising rate fuel pressure regulator
3. Fuel pump
4. Afr meter
5. Boost gauge
6. Oil lines (This requires you to unbolt the block from the frame)
7. Coolant lines
8. Headgasket
9. Crankcase Ventilation
10. MAF relocation
And I'm sure I'm still missing a few things
Just swap, end of story
s383mmber1
3,614
Somers New York
Everything. To do it right, you better have a couple hundred bucks laying around after the "swap" and a good chunk of time.
