Traction in first and second is bad and if the road is wet you have to be careful when the turbo kicks in, i think for that goal, and if i had the money again, i would go with a garrett gt42 26psi should do it(used about 1700) with 0.92A/R, 850cc injectors (550) a Map ecu (350) and forged internals. Dont forget the slick tires cuase that lack of traction would make you look bad in the track :cry:
