currently im upgrading my ct26 to a holset he351. i am using the stock exhaust manifold with a ct to t3 flange with a 38mm wastegate port on the side. but when i was bolt it all up i cant put the compressor housing on because it hits the shock tower on the side. i was thinking of my options and one being to mill down the exhaust manifold on both sides, mill the t3 adapter on both sides, and mill the turbo exhaust inlet, which would probably bring the turbo closer to the engine by maybe an inch at most. I was also thinking about beating in the side of the shock tower or cutting a section out and welding in a bent section for the compressor housing to fit into, but those both sound like bad ideas. so does anyone have any suggestions? thanks
