Wait... you're an auto right?
That would explain the smoke if you're low on transmission fluid...
Poodles;1132382 said:Wait... you're an auto right?
Zumtizzle;1132387 said:How much did a brand new starter run you? or is it a reman toyota?
Poodles;1133053 said:Fluid leaks and hits something hot, hard to tell if it's coming out of the exhaust or not...
Fix the tranny and then see if it does it again...
mk3forme;1134211 said:Are they going to replace the high pressure line or did they not put new crush washers in when they took the front end down the first time? If you need a new line then dont get an OEM. Buy one from driftmotion. Its stainless braided and much cheaper. I think a new on OEM is like almost $300 or something rediculous. Are they going to rebuild the tranny or just replace some parts? When are you going to stop spending money on that thing and get a real car? LMAO I need to sell you one of mine! =P
