I'm going to need to install some new exhaust manifold studs.I plan on installing helicoils first,then the new 10 mm studs (1.25 thread I think).Is this the normal fix?Or isthere an up grade I should do,particularly with a bigger turbo upgrade coming up.So far I haven't foumd any stainless studs to use with the fine thread.Use factory stock I guess?Thanks Sorry if this has been hashed over before,I'm and old noob
