Turbo Decision
8T7supra
78
New York
i am looking to buy a new turbo for my car i was originaly going to get a garrett gt3582r but ht eplace where i am getting the rest of my stuff from cant get it. they suggested a precision sc61. they are both T4's and .68 A/R
but the garrett is dual ball bearing and the precision is only a single. i was just wondering how much of a diffrence their is between them and if it is worth it to find the garrett somewhere else. thanks for the help.
dbsupra90
toonar
indiucky
there is about $500 difference haha.
i love the 61's, and basically its like a non bb gt35r.
fyi, i currently have the 61 on sale for $749. you can get either a .58 or .68 a/r. and for the comp cover you can get an E (3" in, 2" out) or the S cover (4" in 2.5" out).
but, to decide on a turbo you need to consider:
how much you want to spend
what power you want on pump gas
what power you want on race gas
what spool characteristics you want
8T7supra
78
New York
what spool characteristics you want[/QUOTE
i am not worried about the price i just want one that spools as quick as possible and i am planing to make about 500 whp
8T7supra
78
New York
i am not worried about the price i just want one that spools as quick as possible and i am planing to make about 500 whp[/QUOTE]
MRSUPRA
838
Maryland
A "regular" 61mm turbo with a P-trim turbine wheel is not going to spool as fast as a GT35. If you go with the PT-61, get the smaller turbine wheel for faster spool; I guess they would classify them as O-trim wheels, although there web site says "To4".
dbsupra90
toonar
indiucky
if you arent worried about price then go with the gt35r.
matt- the small pt61 wheel is called the t-350. its bigger than an O, but smaller than a P
dbsupra90
toonar
indiucky
yep, i have those too. depending on the turbo, they are about the same price as the gt dbb tho. just pay attention to the specs. on certain turbos the dbb version is actually a different size than its journal bearing counterpart.
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
both turbos will respond well, but garrett did good things with their gt series. however, that is just me speaking from looking at dyno charts. i was looking into both turbos for a long time.
MRSUPRA
838
Maryland
Here is the portion of the chart I waqs refering to. this is from nolimitmotorsports.com:
Max. Rated HP Part No. Compressor Specs CHRA Turbine Specs
Wheel Dia. Wheel Inducer Wheel Exducer Wheel Trim Inlet/Outlet Size Bearing System A/R Ratio Wheel Style Wheel Inducer Wheel Exducer Wheel Trim
T4 Race & High Performance Turbos
680 PT-61-A 61mm 2.416" 3.227" 56 3" / 2" 360 Race Tan .58 .68 .81 or .96 T04 2.795" 2.437" 76
680 PT-61-B 61mm 2.416" 3.227" 56 4" / 2.5" 360 Race On Center .69 or .85 T04 2.920" 2.420" 69
690 T63E-A 63mm 2.476" 3.310" 56 3" / 2" 360 Race Tan .58 .68 .81 or .96 T04S 2.920" 2.542" 76
690 T63E-B 63mm 2.476" 3.310" 56 3" / 2" 360 Race On Center .69 or .85 T04S 2.920" 2.420" 69
700 T64E-C 66mm 2.580" 3.580" 52 3" / 2" 360 Race Tan .58 .68 .81 or .96 P-trim 2.920" 2.542" 76
700 T64E-D 66mm 2.580" 3.580" 52 3" / 2" 360 Race On Center .69 or .85 P-trim 2.920" 2.420" 69
745 PT-63-A 63mm 2.476" 3.310" 56 4" / 3" 360 Race Tan .58 .68 .81 or .96 P-trim 2.920" 2.542" 76
745 PT-63-B 63mm 2.476" 3.310" 56 4" / 3" 360 Race On Center .69 or .85 P-trim 2.920" 2.420" 69
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
those are some good charts. how do you like your turbo, and what kind of performance does it put out? ex. pump gas power, race gas power, spool time... blah blah. would you recommend your turbo?
