Bravo Doc. Someone finally brings up coolant bypasses. I was wondering how long it'd take. I don't often run into people who know most engines have one somewhere.
bwest said:I had a jdm ct26 that had its coolant lines blocked off. I never ran my that way, but food for thought...
boltz said:If you look at the 7M cooling system there it has the turbo coolant lines looped with a different configuration for the banjo fittings and rubber hose. Not that it is essential but cant hurt to keep it looped if you dont use coolant on the turbo.
bcg04 said:So blocking these off is a bad idea. Is it then recommended to go to an NA waterneck, or recirculate the turbo waterneck or are they the same. Sorry I still can't seem to figure this out.
