Turbo choice for 1JZ
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
This was last week, Done through a 1jz, no cams, stock head and bottom end. Safc 2,
and a GT4082 on pump and 23psi.
Panchira!
Cressida+1jz+GKT550= :)
Jan 3, 2008
50
black hole
no play in my turbo as of now....maybe running it may make a diference.....but no one that i have heard of had any problems......
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Guys, I was just messing with you.. I'm sure you'll be just fine, my habit of being overly sarcastic is sometimes hard to see over the type.
xsjado
Engine bling!
Jul 15, 2007
252
Melbourne
I figured you were been sarcastic :D, still doesn't help lol. It's a big change with lots of money involved, even the sarcastic stuff makes me start to second guess the whole conversion. Will be a different story once it's finished though. I think I will go with the GT-K 650, TiAL 44mm wastegate and Drewgo manifold and dump. Just wondering if I should get the Driftmotion oil line kit while I'm at it. I will be ordering my Aeromotive FPR kit and some other stuff from Aaron soon. I'd assume the oil line kit they offer is good value like everything else. Will just get everything else made up once it all arrives.
While I'm here, is it worth it to get the replacement 1ST Gear Thrust Washer also? I know absolutely nothing about the internals of gearboxes... How hard would it be to change out while the engine swap is getting done?
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
xsjado;980495 said:
I figured you were been sarcastic :D, still doesn't help lol. It's a big change with lots of money involved, even the sarcastic stuff makes me start to second guess the whole conversion. Will be a different story once it's finished though. I think I will go with the GT-K 650, TiAL 44mm wastegate and Drewgo manifold and dump. Just wondering if I should get the Driftmotion oil line kit while I'm at it. I will be ordering my Aeromotive FPR kit and some other stuff from Aaron soon. I'd assume the oil line kit the offer is good value like everything else. Will just get everything else made up once it all arrives.
Well, as far as I can tell its not the easiest thing to do.. at least a home job, in fact I think it would be rather difficult unless you had all the right tools.
Before starting swap I was researching it a bit and it seemed more worth it to wait until the damn thing went bad before replacing it, unless you know its going out. In that case perhaps worth it.
I don't have any more info than that but I'm sure the more experienced will know far more than I.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
cbutler;980016 said:
Nice numbers.
Why didn't you hit rev limit at 7200?
Kinda funny, my 3rd hits the rev at 7200 but my 4th lets it ride to 8200....
I confirmed that one time on the highway running with a Supra. I was on 4th pegged to floor and did not notice I was approching 150mph in 4th. My 4th is supposed to top out at 129. It got me there. It's a stock ecu.
Panchira!
Jan 3, 2008
50
black hole
well im not taking the chances with the 1st gear thrust washer. so i got a HD one and a HD carrier bearing support bracket from marlin crawler
HD bearing carrier: $45
HD thrust washer: $45 (you have to ask for it they dont have it listed on their web site.)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
In my oppinion, you should use a Holset HX35 off of a cummins motor. I know of someone who may be willing to part with the turbo, manifold, DP and a 50mm knock off HKS wastegate for the right price (probably about what you are going to spend on a turbo alone, or less).
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
You can get them free easily.. just have to know where to look.
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
OOH i just bought the bearing carrier for the thrust washer... Ill have the shop put it in when they rebuild the tranny for me.
