Turbo A. Wiring harness
Sebas
26
new jersy
I have a '89 turbo. I was at the track drag strip last week and some guy approach me. He said he had a true TURBO A. wiring harness for sale from a engine he got from Japan
He said, it's complete with the ECU
Being that is from my turbo A I wouldn't need the afm And I would have to install a air temp. Sensor by the intake manifold
Any of you guys have experience with this??
With this B as simple as it sounds ??
I told him I was going to do some research before getting back to him
JDMMA70
2,550
Houston
Youd need the Map Sensor, so he'd need to include the upper intake plenum (its screwed into the side), Provided you had all the sensors, ecu, and then extended the harness to fit a LHD car, then sure it could work. However turboA's arent exactly a dime a dozen, so few of us have ever touched a turboA harness let alone seen one.
Not to mention if the Ecu was tuned for bigger injectors and more boost which would make the fuel and timing maps way off for a stock setup.
