hey guys this is my first time. so take it easy on me. Here goes. I blew my hg which inturn warped my head and even my block. I bought a used JDM motor from an importer for 1200CAD which i thought was a good deal. Not wanting to ever have to pull it again i decided to tear the new one down and at least do the mhg and arp bolts. once i started to ripe shit off of it things didnt look right, the turbo has a much bigger inlet, the throttle body is bigger, and the fuel injectors are not the same as stock. This leads me to think perhaps I get a turbo-a moter? if this is the case I am happy but I am still using a 1989 carcass with the original wiring harness, cpu,and maf. Some of the sensors are different so I'll change them, but will this thing work, If so what should i do to cause the least headache. basically can i drop it in, hook up the wiring harness, the stock maf and go or what? I am adding a full 3" exhaust ,hard pipes and a boost controller, but that dosn't have to do with my question.
thank you for your time
