Trying to cure Boost drop off..
Turbo Habanero
4,229
Tucson,AZ
So i've had this problem for who knows how long as i just decided recently to start turning up the boost.
As of right now my boost will hit 17.5psi (3rd gear pull from 40mph) and not hold that for even a second before falling slowly to 12.5-13psi by redline.
Any help or insight is welcome and appreciated.
Things i've checked and double checked
BOV is nice and tight
All IC pipes have great solid mounting surfaces and all T-Bolt clamps are Fastened correctly
Vacuum to Boost Gauge is nice and tight
Vacuum from turbo and waste gate to MBC are clamped
Checked all Vac sources through out engine (Insight on what one's would cause boost leaks would be help full)
My mods that relate to this Problem
CT26 60-1 with stock wastegate not Shimmed.
NXS MBC (EBAY) with about 5inch vacuum Lines http://www.ebay.com/itm/NXS-MANUAL-...es&hash=item3c9db9eeae&vxp=mtr#ht_1508wt_1061
Driftmotion Intercooler Kit with a Knock off Tial 50mm
Things that i think could be causing the issue.
20+ year old waste gate
or Cheapo MBC
te72
Classifieds Moderator
6,610
7
WHYoming
I know Turbosmart's more pricey EBC's suggest that they prevent high rpm boost drop off, but have no experience with them myself. Might be worth looking into.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I have the Turbosmart Eboost Street with the feature Brad was referring to with my 57 trim ct26, and it actually works fairly well. I used to spike and drop 3 or 4 psi by redline, but with this boost controller it still spikes a little but holds boost all the way to redline.
Turbo Habanero
4,229
Tucson,AZ
Thanks for the reply's guys.
Airhead let me know how much you want for it and to ship to 85742 Tucson AZ I Appreciate the help.
On a side note if I get this problem fixed I'm going to need some wider tires lol. I think the boost drop off helps me with traction in second :)
Turbo Habanero
4,229
Tucson,AZ
I get paid on Monday I would rather pay you for it but I Appreciate it tons.
Is there a way to rebuild the stock waste gate ? Does anyone have a link or any info or doing this? Is it as simple as replacing the springs ? I have no clue when it comes to our internal waste gates.
airhead04
1,489
Lima, Ohio, United States
No need to pay me man, I have like 4 of them. lol. Send me your address in a pm and I will get it out tomorrow for you. And I dont believe you can rebuild them. I think its a sealed unit. Dont quote me though! lol
Compton74
355
Long Beach
not to go off topic at all but great job with the intro post habanero, makes it so much easier to help identify and fix issues when you've already told us whats up! props to you
