Broke a rear, drivers side wheel stud when putting my wheel back on. Having trouble removing this rotor, I did try to search for other people having the same problem but everyone says there are two holes you use to push the rotor off. Not sure if I don't have them or perhaps I'm not understanding. I also read to re-adjust the e-brake using a small screw driver in the whole on the bottom, but in previous threads I've heard that isn't necessary if the e-brake is disengaged because it shouldn't be making contact to hold it on. I thought the cotter pin and 32mm spindle nut might be holding it on but I've read they are also not necessary to remove(thank goodness because mine is rusted on there Tight). I wouldn't mind replacing the rotor if need be but I'd prefer to not beat the hell out of it with a sledge for fear of ruining other parts. Attached a pic so everyone can get an idea of what I'm working with. it's an 86.5 5 speed manual if it helps & yes I've looked in several different manuals they all say to adjust the e-brake down using a small screwdriver in the adjustment hole.
