Alright I switched throttle bodies on my supra and it fired right up like it should, but tjen as I would come to a stop the idle would drop under 500 and occasionally die. Now whenever I open the throttle and let go it was to die. Is thay my tps?
you sir, are cruel and unusual.jetjock;1935581 said:I like replacing the fuel pump idea....
80083r;1935684 said:- the fuel line going into the pump was very thin walled - so after 25ish years, I guess the flow of liquid has worn them down some....
3p141592654;1935511 said:So fuel pressure is low? What pressure did you measure?
jetjock;1935744 said:If I were cruel and unusual I'd be all over that like white on rice :icon_razz
crack me up
Nick M;1936001 said:So your car runs just fine without a working airflow meter but it is hard to start?
dayton.frey;1934346 said:Once its started it runs great. Thanks
dayton.frey;1934346 said:it fixed the issues with the starting issues and from bogging out when I stepped on the throttle
