i've been running stock boost for about a year now after my headgasket job. Before that, when i got my ddp, i was using a manual boost controller that i was given from our friend empera. the problem i had then was when the mbc was installed, i had max boost, or boosting till fuel cut(14ish) with it adjusted to as much out as possible. this was back when it was automatic, mind you. i didn't know what the deal was, but i didn't bother with it after my HG job.
well today, my buddy was bitchin' to me about how my damn wastegate is always open and about my boost leak at around 12psi that i never fixed. Ever drive a supra with a ddp on stock boost? hehe, yeah it makes a lot of noise just driving around normally through the gears. so, i had nothing to do today, so i decided to do this shit.
Fixed the boost leak and installed the mbc. Same problem as before. I have the screw undone as far as i can, and bam 14psi with fuel cut through any gear. I can't drive it past part throttle.
Anyone have any idea of what it can be? i know i have it hooked up correctly. Can the mbc be faulty? i took it apart and looked over the whole thing and it seems fine. Any ideas or anything is appreciated.
Thanks.
Thanks.
