Trig people enter here
tte
Breaking In - in progress
Northern California
swaq said:
Z = sqrt(4.5^2 + 2^2) = 4.9244289008980523608731057074588
...I need to go to class and take my midterm. I assume Doward or someone will solve it before I get back.
Z is correct so that means it is not an isoceles triangle.
Did you get all the info you need John?
Cheers,
Roy
Doward
4,245
Alachua, FL
roflmao, yes, you had Z correct, if the LENGTHS were correct - but your angles were wrong in that case.
*edit*
Give me a minute, I'll work it all out. You need X and Y, correct values, right?
Z = 4.9244289"
Bottom inside angle of the triangle = 23.9625 degrees ( = arccos(4.5/4.9244289) in radians)
Upper inside angle of the triangle = 66.0375 degrees ( = 180-90-23.9625)
Of course, now our lower triangle's measurements are f'd up.
Upper angle of the lower triangle = 23.9625 degrees ( = alternating interior angles of two parallel lines)
What about the other two angles of the lower triangle? Well, let's take a look at the LOWEST triangle.
If you extend the line segment forming the vertical of the right angle in the upper right quadrant, down to the bottom of the diagram, you find that you have a 35-90-55 degree triangle. Again, using Alternate Interior Angles, we find that the former 100 degree angle is in fact 125 degrees (180-55)
Thus, our lower triangle is a 23.9625 - 125 - 31.0375 triangle, in degrees.
Now back to our Law of Sines ;)
X / (sin31.0375) = 4.9244289 / (sin125)
X = 3.09958393"
Y / (sin23.9625) = 4.9244289 / (sin125)
Y = 2.44155023"
This makes sense, since you are saying that your upper horizontal is 2.0", and you have a 35 degree incline, you'd expect about a 2.4" measurement there.
Anything I miss?
*edit* Just a small aside, things like this are why I cracked up laughing when I read a friend's fanfic of FF7. It was Cid Highwind (the engineer) yelling to another that they needed "Trigonometry and an ass-kicking!"
tte
Northern California
To get Y :
A = 2.00"
B = ?
Angle = 35 deg
B = 2.00 tan 35
B = 1.40"
Y is the hypotenuse so Y = (1.4 ^2 + 2^2)^0.5
Y =2.44
To get X :
X= 4.50 - B
X= 4.50 - 1.40
X = 3.10
Cheers,
Roy
OneJoeZee
Retired Post Whore
aboard the Argama
You know you're a nerd when you get excited by the fact you got the same answer to a problem as someone else.
This happens all the time in my class. What'd you get for #4? pi/4? AWESOME!! HIGH FIVE!!
tte
Northern California
As for the problem, if one is not good at Maths, Just draw the diagram to a certain scale and you should get the answer althought calculating it is more accurate.
LOl...I miss university classes.
I am thinking of going back and doing a biomedical/biochemical degree while I work at my engineering job.
When I went for my interview with UC 2 weeks back, they told me my eyes lit up when talking about studying.
I love learning new stuff and esp doing R&D work.
I guess its time for a change again.
Cheers,
Roy
