Tricky Wiring: Depinning the oil pressure sender and water temp sender
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I made a little wiring connector service tool per the Toyota Repair Manual directions. I can depin just about every connector but the single terminal water temp and oil pressure sender.
Does anyone know how to de-pin these? The oil pressure, I can move the locking tab up and release the pin a small amount, but it catches on something else. I can't see any other locking tab or possible moving part in the connector. For the water temp one, I cant even feel the locking tab. I'm at a loss. :(
Anyone done this before?
Idk what the plugs look like but sometimes there is a piece that needs to be released before being able to pick the tab and pull the pin out.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
For anyone that sees this in the future:
The oil pressure has a very forceful tab you must pull up on. Takes a lot of force compared to most other connectors. Once the top tab is pulled out, it comes out like any other terminal. It takes so much force, I was sure that tab wasn't a movable piece.
The actual terminal is quite intricate. It's far from a standard spade terminal that I've seen. Haven't been able to find one anywhere and I'm afraid I might have to hack one of the terminals I have and splice it together.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
If you have the pre 89 water temp sensor then the pins and connectors are identical to that of an EV1 injector connector. A google search will show how to depin one of those without much trouble, just need something small enough to fit into the small opening above the pins.
