Tricky Motor
alucardunit1
82
Lee's Summit
Alright i have a GTE that has a 87 head on it but a 89+ block. what wireing harness do i need to get or are they all the same? only reason i am posting is because of the difference in the block and head.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Doesn't matter that I can think of... the wiring harness doesn't connect to the head at all, and on the block the only things are the oil pressure sending unit and the knock sensors, all of which use the same connectors for all years IIRC.
kakanator
400
Fresno, California, United States
the injectors clips for the 89+ are different then the pre89. The knock sensors are the same I think the vsv's are the same the cps is the same the coil packs are the same the 89+ egr has a sensor on it and the pre 89 dose not. Just get a pre 89 harness and pre 89 injectors. Also depends on what ecu you have.
alucardunit1
82
Lee's Summit
sorry me and my dad are getting each other confused on this he use to work on american cars.
when getting the ecu and wireing i need to get the same year as my car right? or ecu same as the motor and wireing same as car which one lol
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
It's easiest if the wiring harness, ECU and chassis harness are all the same. So if you've got an '89 car, then it's best if the wiring harness and ECU are also from an '89. The ECU and engine wiring harness must match, but they can be different from the chassis harness with relatively minor issues.
However, I have the wiring harness and ECU from an '87 in my '89 car, and there were very few issues. The ABS connector was different entirely, and the headlight relay needed to be re-wired.
alucardunit1
82
Lee's Summit
I dont have abs and how hard was it to rewire the headlights but i have the same thing i have 87 ecu and harness with a 89 car
Sent from my LG-V909 using Tapatalk
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
It's in here somewhere, that there are 2 pins that need to be swapped at the place where the chassis harness plugs into the ECU.
I didn't know that at the time, and I cut the wire at the headlight relay and at the #1 integration relay, and ran a piece of 20 gauge wire between them, haven't had a problem since.
