This was discussed to death before.
Shawn (dude) took many measurements, and found there was little to be gained by tying the front strut towers together across the engine, but much to be gained by cross bracing the front strut towers to the cowl area. (He agreed the cowl was not very strong, but by spreading the force out over that area, would be strong enough.)
So, the CP X bar is using that information pretty well I think. (At 150.00, is a pretty good deal too.)
The ebay bars going from tower to tower don't acomplish much on a subframe suspended vehicle like the Supra. (I think the brace from the rear of both A arms underneath is a good mod, it would reduce flex in this "open" end of the cradle. Is it Cusco that makes that piece?)
I've thought that combining the Cusco lower bar, with the existing bolt in stock brace in a X design would provide better steering feel.
Short of a full welded in cage, or starting out with a hardtop car, your always going to have flex problems with the Targa. (In place or not.)
What I've seen done to improve "muscle" cars is welded in sub frame connectors, X brace strut bars that tie into the Cowl, and triangulate the engine bay. Also some X braces in the rear suspension area designed to reduce chassis flex. The old Mustang guys have some really cool stuff available. They had a stock cross brace going from the towers to the cowl, so the mounting points are factory. Then some kits use alloy tubes, heim joints and trick brackets to fully X brace the engine bay. (It makes a huge difference on the Mustang, so why not on a Supra?)
I think one of the ways the DoLuck RXB makes a difference is preload. If you just tie the bar into place, but don't preload the chassis, it will have less effect.
I know from building Limo's back in the 80's that short of a cage, you can add some strength by stitch welding the factory panel seams (Welds about 1" long every other inch.) This makes the most of the struture you have. Also some simple straps welded across open areas in X patterns can make a huge difference. We used mild steel 1 or 1.5" flat strap in various thicknesses. This was about the only way a large floor panel could be reinforced to handle 9 people crawling around on it without flexing too much.
I imagine that similar results would be found using these techniques with the Supra chassis, but more to improve the handling feel than hold 9 passengers
LOL
The one mod that nobody is talking about much, but that would make the car much less inclined to flex or twist is a tunnel brace. If someone could close up the driveshaft tunnel, with a flat panel brace that turned the open "U" of the tunnel into a closed "O" it would reduce twist and flex across the open floor pan area of the Supra. (Targa or not.)
Just a few thoughts.
