Transmission and diff questions
Intrnlstorm
One Jizzle
Aug 27, 2006
123
Schenectady, NY
Well the car finally runs and I got her on the lift today. I found out that the transmission leaks and the PO caulked the bottom of the transmission.
What is causing this leak? ie what do I need to do when I drop the transmission?
Second question. The LSD diff is whining. The PO gave me another LSD diff that he swapped out because it was whining. Do you guys think it is the gears that are whining or maybe bearings? Or maybe something else? Are they worth rebuilding or should I just buy another one.
Thanks,
Joel
OneJArpus
2,798
IIRC, trans would have to be opened and resealed.... If your doing it yourself and know whats going on you can rebuild it... or just reseal it.... It just uses atoyota silicone made for gear oil.... Replace the seals on it too.. tail seal n front shaft IIRC has one
