Trans Vibration
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
MDCmotorsports said:
Squid, I'd say its either a bearing inside the trans about to explode, a loose trans, or a blown carrier bearing on the drive shaft.
oh please don't say that...my poor old W58 shifter rattles like change in a dryer, i need it to last for at least another 3 months!
gixxer750
2jzget comingsoon!
Mississippi
If you are in a bind, there is a temp fix for the driveshaft bearing.
Go to the parts store, get some urethane windshield sealer, its in a caulk tube. Fill the driveshaft bearing with it from the outside holes, and let it dry for a day. It's worked for me so far, about 4k miles.... It just has to hold until I get my 1 piece driveshaft.
antman
632
TN
ofcourse it reduces the stiffness of the car, and if you hit a bump everthings going to shake. But your car should not shake just riding down the road. top out or not. its not normal.
