Boss302 said:why won't first be usable too short a gear ratio? and why would i have too make a modification for the shifter the MK4 uses the R-154 same as the mk3 the getrag wasn't even introduced until 95/96 i believe.
the only real differences i could obviously see is the clutch system, flywheel, and starter are different. i wouldn't have to get a custom clutch line unless diff. fittings count.
i know it won't simply bolt up a project this big isn't simply going to pop on. shouldn't the bell housing bolt pattern be the same if the Mk4 uses the R-154.
Have you done this before i'm just wondering. on all this stuff i don't doubt your knowledge at all keep all comments coming i appreciate them.
Boss302 said:i apologize for my stupidity and i don't mean by any meens any offense. the reason why i say the N/A Mk4 uses the R-154 is cause when i looked up the part #'s for the 3 and 4 the 5-speeders where the same R-154 even from Toyota and Driveline or Drivetrain.com don't remeber which one it is called.
EVERY one that i talk to says the R-154 went in the earlier mk4's. also i've only heard of the V-160's what the diff. between 160's and 161's?. The V-160 from Toyota brand new costs 5g's rebuilt from autozone(cheapest)3,460 i believe with a 1200 core!!:aigo: ouch.
anything else yall cn think of that would be a pain in my rear for doing this? as for using one of the Generals trannys there's a ford probe with a 2Jz-Gtte using a corvette auto tranny it's really wicked. my friend has a one of the few rare turbo probes and discovered the dude while surfing around for ideas about his car.
IJ. said:No idea how you'd get it to fit.....
Guess anything can be done I'm just finishing off my 9" install here and run a Tremec TKO trans.
NDBoost said:dont make an mk3 a mk4..
Well I've trashed 2 Mk3 Diffs in the last couple of months without a single launch on slippery tires 1 being a rebuilt Torsen with 4000 KM's on it so what do YOU suggest I do? hmmm89mkthree said:now were making an MK3 a ford. IMO thats a bigger sin than making an MK3 an MK4. now do 25 "hail mary's" and 4 "our fathers"....
