Ok at extremes I towed a light load 900 KM's and it didn't suck too much extra fuel and I bought a 1000 KG/2200 Lbs Milling machine home using the Supra
It did it easily.
It did it easily.
IJ. said:Both were done while it was NA.
phoenix6 said:Well Im good at wiring, done alot of it. I just wanted instructions to make sure WHERE Im splicing shit up to.
Asterix said:You'll need a converter box because the Supra has separate turn signal and brake lights, and the trailer most likely has combo lights.
I spliced in right at the left tail light assembly using the 3M T splices that clamp right on with pliers. When I want to tow, I pull out the inside cover and pull out my wire. It hangs out the hatch just fine. When I'm not towing, the wire hides behind that cover.
Look at the wiring diagram over at cygnus.net for wire colors.
Asterix
ps that one at Draw-tite looks a lot like mine, except it has the removable receiver. I wish I had that one. Maybe I'll upgrade soon because mine is rusting badly...
