Think ive narrowed down the play in the rear end to the traction arms, im getting noise and play from the rear end when decelerating and accelerating at slow speeds around a tight corner, im pretty sure its the LSD slipping and causing it to load and unload on whatever bushing is worn out. Just finished putting in a new Center Support bearing and most of the play I had is gone :icon_bigg. Just trying to track down that last little bit of play, at least its livable now.
The pinion has normal play, crush sleeve is good.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=RA&P=70
those are the ones im talking about..
What else could be making the noise back there? I might as well just get all of the parts before I tear it apart. I dont really want do a full bushing job though, the suspension is quiet over bumps, no weird clunks.
