Hey guys, with all this talk about brakes, please don't forget I am having a sale right now.Van;1898977 said:I've had good results getting my racing equipment through Driftmotion, Porterfield http://porterfield-brakes.com/keySearch.php?search=supra&manufId=&_pge=2&_sby=&_ord=and IO Port Racing http://www.ioportracing.com/index.html.
With regard to radiator choice, I picked a Koyo Racing and added a surge tank to add another gallon capacity to the cooling system. For heat removal, I still run an engine undercover, then have the rear of the hood lifted with a few washers on the hood hinges. I used not to run a fan as most of the time I was going fast enough not to need one... I was running a 18 pound radiator cap and 16 pound surge tank cap. The 7MGTE was typically kept above 3500 RPM and mostly in the 4 - 6K RPM range where the engine I had built was designed to run. The engine uses Amsoil 10-30 100% synthetic oil. This August on a 90 degree day I noticed the temp rose to mid way on the gauge. So our engines can get quite hot! I needed to run with short shifting for about five minutes before the temps returned to normal. The engine I run also has a seven quart sump. Sounds like you and the guys have a well built start on a track Supra.
I'm finding RSR racing springs and KYB GR2 are a good set up for endurance racing on a budget. When you can afford it, get the Koni yellow. I also find that the Porterfield R4-1 in front works well with the stock brakes. I use the TRD pads for the rear. I'm finding the stock brake bias adequate for the speeds I'm able to drive. I had to bleed all the stock brake fluid and switched to Castrol SRF, 100% synthetic fluid. A great improvement in reducing brake fade, even on very hot days. Well worth the extra cost. Van
Also I wanted you guys to know that I hold a special place in my heart for people that actually race their cars. If you guys have results, and photos of your car on the track, I would really like to try to talk you guys into a set of our brakes.
I am very surprised anyone can run the stock sized brakes on the track. Then again maybe you guys don't have 17 inch wheels, and that's why you haven't looked into our front brakes.
If that's the case, Mustang wheels off of the first generation that came with the 4.6 liter in it, had some 17" wheels that fit on a MKIII and are pretty cheap. Plus there were tons of aftermarket wheels that were 17x9 that fit that same vehicle. I have seen plenty for around the $100 per wheel range.
