too rich mixture
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
hi guys i have a problem in my 7mgte,the engine start and but the mixture is too rich and smoked the spark plugs,ireplace the s plugs ,test the coolant sensor and the ox sensor but are good.Its posible that the flow meter is bad?:1zhelp:
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
NEVER spend $$$$ on parts you may not need !!! Period !!!
Ask around, alot, and find out who does good diagnostics in your area. Have it diagnosed first. (how do I know?? because I manage a smog repair shop)
I see it happen everyday. They come in telling me how they changed this & that, spent $$$$$$, and it still runs bad, or won't pass the smog test.
YOU can change most of the parts that you may really need.
MOST of the time (95%) we can adjust the AFM (N/A car), or clean the MAF meter (turbo car), and problem solved. SERIOUSLY !!!
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
+1 That should be carved in stone, its incredible to me how some people will throw part after part after part at a problem and then realize it was something simple and they just wasted a shit load of money.
O2 sensor maybe?
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
okay before we go diagnosing a rich mixture, lets verify that the problem is burning gasoline off. What color is the smoke on startup? maybe its coolant burning, or oil. Does it smoke while driving? does it stop after the car warms up? We need more info.
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
O2 sensor maybe?
i remplase the o2 ,i will check if the injectors is bad
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
the smoke is black and definitly is too much gasoline
1TuffSupra
Sho' Nuff
500
Good point, just because a car is smoking doesnt mean its smoking because its running rich. It might be because its burning coolant or oil. You definitely should answer all the questions he is asking here.
Black Smoke = running rich
Blue smoke = burning oil
White smoke = burning coolant
And if it IS running rich your injectors wouldnt be the problem since they would clearly be flowing well. And doesnt the AFPR raise the fuel pressure as boost levels rise? If it went bad wouldnt the car go lean?
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
i mean the injectors because in the past i haved a problem with a mr2 that one injector stayed open and caused a similar problem
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
What do the spark plugs look like after idle? Are there any that apear to be running richer than others or are they all evenly the same color?
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
i will check this tomorrow thanks very much for the atencion
1TuffSupra
Sho' Nuff
500
Ah, didnt think about that. Joel is right though, if thats the problem one or more of the plugs will be much darker than all the others. Very good thinking though, and dont worry man. With all the great minds in here we will definitely come up with a proper solution for you.
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
The problem was resolved ,a turbo to intercooler hose are out,thanks very much guys..
