TobyCat's winter buildup
TobyCat
470
Vancouver BC
Well, the car's been down for about a month now due to ::bhg::
I finally got around to taking the head off of the car a few nights ago, and was a little worried about scoring on the cam journals, and pitting on the block. It looks like whoever did the last HG job when it blew (Toyota:icon_evil ) over torqued it, and #1 and #6 rings on the gasket were out of round. Well, there was my exhaust->coolant leak!
So this is how it sits now, waiting for the machine shop. The other thread http://www.supramania.com/forums/showthread.php?t=49518 with my silly questions :)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
quick qestion did you put any thing in you coolent jakest and oil jackets when you were scraping
i have all wasy used greas and used q tip after wors to gett all the shit out of my block
plus makes scarping the block very easy and faster ????
__________________
TobyCat
470
Vancouver BC
Nope, didn't put anything in the water jackets as I scraped everything wet with lube. Scrape scrape + wipe. Repeat 1000x.
Got the head back from the machine shop and everything looks really good. The head surface is crazy smooth! I polished up the cams with some scotch brite, and it turned out well. Got all that scoring out. I assembled everything but didn't do the final torque down ... didn't have any RTV for the #1 cam caps.
I measured the head height and it came out to *just* below 116mm (4.553")which is the factory thickness. So, that means that when the old guy I bought this supra from got his headgasket done in 1998, Toyota didn't even bother to get it machined. :icon_evil
Final pics is how I tucked the ol' supra away for the night ;)
TobyCat
470
Vancouver BC
Yup, that's the plan. Going to start it up with fresh water/oil and let it run for a bit. Drop the water/oil and refill the coolant and oil with good stuff.
TobyCat
470
Vancouver BC
2am home time, and almost done. Dang, took a bit longer than expected to get all that random crap back on. Should fire up tomorrow!
TobyCat
470
Vancouver BC
She's ALIVE! except I've got leaks of all sorts ;)
First fire up, was OK then noticed I was absolutely pissing fuel somewhere. That was easy to find, I didn't tighten the damn fuel dampener enough.
Next, fired it up and everything was OK...until it started to warm up slightly then coolant everywhere. I mean, WOW. After poking around, and filling up some coolant again I heard dripping. The coolant hose that goes underneath the throttle body popped off. Apparently I need to put a clamp on those :p Wow, that's tight access in there without taking the upper intake off.
Ok, fire it up again...and I watch the blanket that was over my fender flap a bit in the wind. I think to myself "I should move that" and right then it gets stuck into my fricken fan. OMFG. Good thing I turned it off in time. What an idiot move on my part :(
So some time later after taking off the belts and jazz (that blanket worked itself nicely in the alt belt) I got the blanket out and noticed that during all this the damn overflow hose/nipple broke. ARGH. So, I gotta tap that with some sort of brass fitting, or at the very worst buy NashMan's old rad. PLeH, more money.
Then, after I quadruple check everything, fired it up again. It runs really good, but I'm still smelling a faint fuel leak. Poke around, and the dampener is still leaking. It leaks out the top and what not, so I gotta buy a new one of those. Add on top of that, lots of the old hose clamps are weak from 20 years of sitting there, and hoses getting old, I've got a lot of twiddly stuff to do tomorrow.
But, I should have my car back soon!
Mrbaboon
277
Victoria, BC
Newb.
That was totally a 4 hour job.
Did you do your valve seals, you cold-start-oil-blasting-newb?
ahah.
At least you aren't rocking the tercy anymore.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
you did put 2 crush washer on the damper right one on top one below the caseing broek i have spare
TobyCat
470
Vancouver BC
Found all my coolant leaks, my friend came by with a coolant system pressure tester - awesome tool! Pump it up to 0.9 bar (13psi) and go around the whole system listening for air or looking for drips. Of course, the heater core<->block hose was leaking WAY down there...argh should have checked the hoses when the head was off ;)
Tomorrow = new fuel pulsation damper (thanks Nashman!) and it's back on the road.
TobyCat
470
Vancouver BC
Fuel pulsation damper installed, and no fuel leaks. I let the car idle up to operating temperature and looked for coolant/fuel leaks ... nothing! The only thing left to do now is time the car and drive it home.
