Well the drain line still uses a flange, so the stock one should still bolt up. Ill have to swap the fitting from the thermostat housing as this has the line threaded directly into it. If I can get that fitting, and as long as the oil supply line is still the same thread and I can put the banjo bolt back in it should work. I was pretty doubtful I would be able to run it now but, it would save me some work and I wasnt sure. No harm in asking, and Luis I have my ct from the other motor sitting on a shelf but thanks for offering. If you want to help me put the motor in though that would be a big help, should be able to get it in the next time I go home.
