To retorque or not to retorque after 6K miles....
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
I've been doing some reading and never knew head bolts should be retorqued early into the break in period. Its been 6+K miles since my rebuild with new ARP (at the time of rebuild) everything. Is it a good idea to retorque after so many miles? I'm not positive what kind it is but all i know is its a 2.0mm metal HG in there.
figgie
Twin Cities, Minnesot-ah
Headbolts.. i would consider a retorque.
Headstuds, no need to.
Edit: Massive brainfart moment!
I am leaving my initial response just for sake of non partialism :)
Head studs do in fact require a re-torque. Heat cycling tend to settle stuff down......
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Sorry to thread jack, but i did not want to make a whole new thread. Is it a good idea to re torque after just about 500-800 miles? I replaced the head gasket on my 7mge with a stock replacement and new Toyota oem head bolts about 5-800 miles ago. I did a re torque after 4 heat cycles, but should i do it again after this amount of time? I am mostly concerned because the head bolts are brand new and may have stretched a little bit. I was reading that it could be dangerous because you could get coolant under the sealing surfaces? Maybe that was only if you hadn't already done a re torque? Thanks for any clarification!
shaeff
Kurt is FTMFW x2!!!!
11
Around
Retorquing is easy. My question would be: Why not? ;)
JDMDrift
Michigan
The safest way to find out if you should is * just do it * it can't hurt it as long as you don't keep going up in torque keep it to what you had it the first time, Hopefully not 54 ft-lbs :)
