To PPS or Not to PPS? Now, that is the question....
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
the PCV is in the rack housing itself, the pump has a different sized pulley for higher pressure.
i have Never seen a PS pump with a wire going to it even on a PPS car. Got pics to show said wire Lange?
i also checked with a local parts dealer and the PN for the 88 NA-Turbo PS pumps are the same as the PN's for an 89+ NA-Turbo PS pump. I don't see a difference between the two.
The Reaper
Jan 10, 2006
1,909
Florida
no but i was stating that i am not dumb. you were explaining it to me as if it wasn't JUST the ease of it and all that stuff.
i was saying im not dumb and that i know how it works. Never said you called me a retard.....did I?
The Reaper
Jan 10, 2006
1,909
Florida
Progressive Power Steering
basically it uses a speed signal to tell the rack how sensitive to make the steering.
so stopped or low speeds it is easier to turn the car, and at highway speeds it's practically turned off to make it a little stiffer and not so easy to turn to make the car more stable at high speeds so you don't slightly turn the wheel and fly off the road
csnow
Matthew 6:33
Palm Bay, FL
IJ.;893737 said:
Chris: If you do use the PPS rack make sure you use the correct sized pump pully to suit.
I am going to use the pump from an Aristo 2J. I am assuming the Lexus cars have PPS so I am hoping the pressure will be close.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
AF1JZ;893693 said:
I have the PPS rack in my car. But, I don't even have it wired up and it is just fine for me.
I forgot to plug mine back in after dropping the engine back in once, and found it incredibly annoying. I was pretty sure I'd managed to kill the PS pump somehow, until I found the extra plug...
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
one of these dasy i gonna get around to finshing the controler so i cna have the feed back of what i desire
ValgeKotkas
2,224
Over the pond
He said, maybe mine's similar. Aaaand..if it is similar, it should then be one year ahead of Jap Supras (mines 87, made on Dec 86 :)). That's why I said so.
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
IJ.;894978 said:
Same pump different pully to overdrive it and raise pressure.
The electrics are in the rack with a bypass valve to reduce assistance at speed.
The pump also has an electronically controlled VSV for the PPS, and (in North America anyways), the pulley is the same between PPS and non-PPS.
