i have already done the leak test on the ic pipes there perfectly fine. i checked the bov and its good, but i dont know about a slow leak in it.
87supraturbo19 said:i have already done the leak test on the ic pipes there perfectly fine. i checked the bov and its good, but i dont know about a slow leak in it.
oh i did kiss it goodbye we dicussed this earlier. still trying to figure out what caused it.IJ. said:If the line to the WASTEGATE actuator is leaking it would let the motor overboost and maybe detonate but fuel cut "should" prevent that happening.
If you were running low octane fuel and the above happened kiss the HG goodbye....
