IJ.;1294604 said:Mine is pretty sad looking from jacking it up there
I'll reinforce it and add a jack locator when I pull it to install the Poly bushes.
So it turned out bad for you ?
I so far have seen no repercussions of this yet.
Ryan;1294167 said:Also what color should the trans fluid and differential fluid be?
Im sorry about asking alot of questions but I really dont have anyone to teach me.
wolfman_matt;1294394 said:So I tried to get under my new Supra for the first time today to change the oil and found that I can't get my jack under the front cross member (which is what I do with all my other vehicles). I have used the pinch points in the past with my other vehicles when rotating tires. Are the pinch points that much weaker on Supra's than other vehicles? Do they make low profile jacks that will fit under the cross member? Or have others had success with Mass' approach?
92TealSupra;1294625 said:So it turned out bad for you ?
