Mr.PFloyd;1386568 said:does that setup work with a stock motor setup? i am assuming you need to run a alt lowering bracket.
yer bro thats all you need...
chefma70;1386572 said:now that i look at it.
A. im going to steal that ffim idea and
B. IJ pointed out a very good point you should flip your u bend over i think it will keep the flowing air cooler since its not going over the hot side of the turbo.
A: go nuts lol..
B: running it in the other direction, will force me to use very sharp bends which i really dont like using in my IC pipe designs... that and its purely just for maintenance sake, running it that way just clears up room around the CAS and sensors area.... bonnet will be getting air vents above turbo (eventually) to keep bay temps to a min.... turbo rear housing will be getting sufficient heat shielding also...
other wise, i'm going for a clean sleek look in the engine bay.... well trying that is.....
keep the comments flowin, and throw me some new ideas...
