hey all..... thought i would post this up, to see what everyone thinks etc...
currently building this for a forum member Kim aka MK3_7m {as i think i'm the only insane case in Melbourne Victoria (Aus) that would accept the custom work lol...}
his car is a Manual 86.5 MK3 supra with Targa Roof so here goes....
basicly new engine....
Mahle pistons + rings + gudgeons
Trust MLS head gasket
Gates timing belt
New oil pump
New water pump
New tensioner
ARP stud kit
New gasket and seal kit
New main + big end bearings
Full chem clean
bore + hone to suit new pistons
crank linished
balanced rotating assy
cryo'd rods
Head reco + skim, valves reseated etc
assembled by a performance engine builder
everything has been cleaned and painted so it looks like new.
supporting mods
AFC NEO,
pte 550cc
walbro 255 fuel pumo
aeromotive AFPR
evo 9 BOV plumb back
evo 6 intercooler
3inch elbow & down pipe
custom made 3 inch exhuast
and the chosen huffer is the: sound performance turbo sp61gt non BB (apparently the first one to be run in Aus.... go figure...)
heres some progress pics so far... dont worry if your following this i will keep you updated...
Kim's basicly said, he wants the engine in and running around 450bhp (dont remember if it was ATW or not but lets see how we go)... so i'm left with free range to go nuts with ideas..... so lets begin.... the pictures should show everyone what the image in my head was....
so the car was originally N/A right.... so to get the turbo engine in we had to use a new loom from a turbo car... seemed fine and dandy till i found out it was an Auto loom with a S*#T load of extra wires, and using an Auto ecu set to neutral... so this was almost a few days head ache...
at the current stages...
oil relocation lines and etc...
fabricating new mounts for Alternator in A/C position, the flex brace on the back is missing but you get the picture...
my version of the FFIM (i cant believe some of the bloody prices' some places want for a custom one and only in the US so add shipping etc... its like selling a kidney!) loads cheaper and less headaches from moving everything around for the custom one.... owning a plasma cutter really does come in handy, if you really hated someone, just write "YOUR A ........" permanently
current situation.....
oil filter mounted behind driver side fog light (well US passenger side), with larger oil cooler and Earls oil thermostat. -10AN fittings all round
i shall keep you all posted..
Cheers,
Jerome..
Gates timing belt
New oil pump
New water pump
New tensioner
ARP stud kit
Full chem clean
crank linished
cryo'd rods
supporting mods
AFC NEO,
pte 550cc
aeromotive AFPR
evo 6 intercooler
Cheers,
Jerome..
