Tire pressure
supraman7mgte
Shut up,bitch!!
Sunny California
Just remember that you need to check the tires cold,say on a 40 psi tire,and it reads at 36lbs,your fine.
Driving around will cause friction which in turn will cause your tires to increase in psi,why I don't know.
friction=heat and the more heat the more pressure.
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
somethings rong with one of em i swapped the left with right and now it pulls to the right, even when i threw the bad one on the back the steering shimmyd but then again the tires dont sit straight either so cant say wats wrong till balancing alignment.
supraman7mgte
Shut up,bitch!!
Sunny California
Are the tires the same tread pattern?
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
I keep mine at 33 Front and 35 Rear. Toyo's reccomendation. Keep in mind they are very soft tires that get very warm and no doubt make a little more heat to up the pressure than in a normal everyday street tire.
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
no their was more wear on the outer tire than inner obviously they were low on pressure seems is good i did 35 all around
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
Why do i have so much resistance from the left side of the car, i took the front left off and and it stopped pulling to the left i threw on a spare their,, and now it fuckn pulls to the right ,, and still goddamn shimmys like theirs no tmrw , tires are old n shity is that wats causes this??
yes. bad tires can make the car pull. along with alignments, rack bushings, tie rod ends....
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
i cheked the tie rod ends and the only play i found where the swivel which i think their supposed to do, i lifted car and did the tire check and their was no loseness their.
steering rack bushing i head cud be it but i havent checked or really even kno how..
ya if you switch the front tires and it pulls the other way or gets better its usually the tires.
mtx911;1494943 said:
when they do alignments they adjust your tie rods right?
anything else?
that is for the toe adjustment and to make your wheel striaght.
camber and caster is also adjusted.
