Tips on Steering Column and Tierod replacement!!
87turbotarga
Turbo freak!
May 10, 2010
96
Richmond
Well i just ordered the parts to hopefully fix my 87 Turbo Supra. I have to replace the end piece on my steering column, The piece that the actually steering wheel is attached to along with the ignition, and my inner and outter tierods along with the bellow boot. Any suggestions or tips on these parts? I will be jacking the ar up in the grass to do this :(
shaeff
Kurt is FTMFW x2!!!!
11
Around
Pulling the steering column isn't that difficult. Two 17mm nuts right at the dash support brace, one nut on the universal joint under the hood, a few 10mm bolts at the base.
Remove the theft deterrant ECU, and unplug the ignition wiring, etc. Shouldn't take you more than an hour or two.
87turbotarga
Turbo freak!
May 10, 2010
96
Richmond
I will for sure use jack stands. As far as the column goes should i unplug the battery first and then go from the inside of the car taking of al the trim and unplugging all the plugs and the unbolt? or do i have to pull out the intire column at once? cause im only replacing the end bar on it.
grimreaper
2,180
Dallas
I did my tie rods in the parking lot at work 2 years back. Really easy IMHO compared to some cars that push the rack behind the motor...
89nasupra
Sugar, Water, Purple
Apr 8, 2008
501
Lafayette, Louisiana, United States
Yes it is always good to disconnect your battery before you do any kind of electrical work. As for the tie rods if I’m not mistaken there is a special tool you need to take the inner rods off. Something like this http://www.restockit.com/inner-tie-..._source=googlepla&utm_medium=affiliateprogram
But you may be able to rent one form a local parts house. The outer tie rods are easy. A good solid hit with a hammer on a knuckle and they should pop right out. Just leave the nut on the bottom incase you miss..lol Good luck
87turbotarga
Turbo freak!
May 10, 2010
96
Richmond
Sweeeet. I just got all my parts today. Ive looked up how to replace everything and it actually seems really easy. Im hoping that i didnt fuck anything up inside of the rack itself because my buddy said i couldve fucked up my gear in the rack or something? But to me it just looks like the tierod got fucked and the boot ripped. Tomorrows my day! :) ill get on tomorrow night and let you all know how everything went. Thanks a lot for the help you guys rock.
87turbotarga
Turbo freak!
May 10, 2010
96
Richmond
Okay i jacked it up and got a good look. i now see that im going to have to replace my lower control arm :(. im going to go ahead and put on the boot and tie rods aswell as the ignition end anyways. i guess ill have to wait to have her up and running until i get the lower arm passenger side
