I installed a new belt but the method used to set the tension is confusing in the Haynes manual. The arrows in the manual indicating the measurement points aren't eguall distance between the pullys, should it be? How do most do this? I have rotated the engine two rounds with the tensiner bolt loose then tightened it bit I'm stuck on how to insure the tension is equal as suggested in the manual.
