Time for some Maintenance/Repair Qs
johnathan1
Supra =
Aug 19, 2005
5,056
Yea, I was able to get my vc gaskets two times at autozone, and they were in stock for $30 (Fel-Pro)...
As for the water pump...mine was leaking as well...i just replaced it, and put a layer of silicone all the way around it's gasket and it hasn't leaked since...It's really easy to replace though...
Steps:
1. Drain Coolant
2. Remove radiator
3. remove fan & coupling (clutch)
4. Remove water pump
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
right, i did read that. but the tsrm always seems to make stuff seem easy. i wanna know if its as easy as they explain. someone tell me its a flawless 2 hour job and i'll be stoked.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
is it worth buying the authentic toyota water pump over the oem at strauss auto or whatever? i can get it for 60 at straus and like 100 and change at toyota
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
so an update and what i did out of that list up there.
sparkplugs-changed
fuel filter-changed
valve cover gaskets-changed
water pump/coolant flushed(bought the $60 one at staruss)-changed
thermostat-changed
still left:
-drain tranny fluid/replace.
question about that...if its red and doesn't smell burned, should i still change it? i dont know when it was replaced...
-recharge AC(yeah a little late)..yeah i know im adding to the list
and last and one most dreading- suspension install...happening tommorrow.
i keep kickin myself for not having my camera on me. i love taking pictures of the engine all apart 'n shit.
