Time for more education...
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
So I'm not totally lost anymore, could someone explain the 1JZ and 2JZ thing? Was the 1J made for MKIII's or did they come from a different vehicle. Is there an N/A model? 2J made for MKIV? Did they come in any USDM vehicles?
Signed
Still learning in DFW
Ken
aye mate
Hiatus over.
Maryland
1jz-gte, 2.5 Liter Twin Turbo I6 came in 89+ MKIII Supras (hence why you need 89+ subframe or mounts to do the swap) in Japan only. The 1jz-gte also came in the Soarer and Chaser I believe, but only in Japan. There is no NA model of the 1jz that I am aware of.
2jz-gte, 3.0 Liter Twin Turbo I6 came in 93+ Toyota Supras in all countries. There is an NA model called the 2jz-ge, which came in NA Supras, Lexus GS300s, SC300s(later model Soarer in Japan I believe) and IS300s(Altezza in Japan).
I think I am right about most of it. If someone sees something thats wrong please chime in.
PS- I think your signature might be too big.
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
there is a 1jz-ge. dunno what it came in though.
Fletch124 said:
To swap a 1JZ into an 86.5-88 you need an 89+ OR just 89+ engine mounts?
89+ mounts don't fit the pre89 subframe without modification.
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
gtsfirefighter said:
So it would bolt right into my 89? Does the ecu plug in just as easy?
89 was a split year. if you hvae the rectangular mounts then you need bic brackets, the round ones will drop right in.
wiring is not plug n play
you really need to search
gtsfirefighter
Sep 26, 2006
2,966
I have 26.4kbps dial up so searching is very difficult, sorry. Was wondering when somebody was going to throw that in.:icon_bigg
I work tomorrow so hopefully I'll have time to do some searching. We have a T1 connection there.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
Searching is something you should've done...doesn't take that long anyways...
But since you've already made the thread and since IDGAF, I won't bitch and moan over anything....;)
EXCEPT...Your sig is 640 x 480 pixels.
It needs to be 650 x 225 pixels or smaller.
Back to thread......:D
gtsfirefighter
Sep 26, 2006
2,966
JoeC said:
Guys, Be nice. With dialup it does take forever and a day to search!
Thank You!! With all the signatures and pictures it takes more time than it's worth. I'm at work today and have been fortunate enough to have some high speed computer time so yes I've been searching.
Also to whom it may concern, I just deleted my sig, it was just an experiment anyway.
OneJoeZee
Retired Post Whore
aboard the Argama
you can turn sigs and avatars off, you know.
