got to say i love these! totally worth the money. the car is lowered but set to a height where i can drive over 95% of most road obstacles. i actually went around measuring the clearances of speed bumps.:biglaugh:. i just have to do my alignment now.
previously had stock suspension. on crappy tires.
settings: 14 in front 8 in rear.
high speed:
could turn down setting a little more for trips.
very little body roll.( i could jump 3 lanes without fear)
not bouncy, perfect rebound.
low speed:
turn corners and not fear fishtailing even when mashing the gas.
bouncy on bigger bumps
wish there was a little more suspension travel
dips into bumps rather than filling in.
brake feel and distance drastically improved
tips:
if you have tems you have to take the rear moldings completely out.
remove 2 washer fluid tank bolts when removing passenger side upper arm bolts.
oil big bolts when putting them back on, makes it easier if you have to remove down the road. i used lucus oil additive.
