It's a 7mgte 87 supra manual.
Another problem I have now that my car is running again... I have a ticking noise. It comes from the exaust side of the engine I think. I'll take a video of it later if it would help.
Basically, while in neutral either idling or reving, it does not make the ticking sound, no matter what kind of use of the gas pedal, lightly heavy, anything, no noise.
In gear and upon accelleration, the ticking starts and goes up with the rpms. It starts at very low rpms even around 1k rpms if gas is given to it steadily enough for the turbo to want to kick on..
While coasting or maintaining rpms the tick goes away, it also goes away under full boost...
I have the BIC divorced downpipe.
I suspect an exaust leak because I broke a bolt off where the downpipe elbow attaches to the turbo. I also know that two of my exaust manifold bolts are stripped and just loosely in there.
What would be the sound/symptoms of an exaust leak?
Does it sound like this is my problem?
Maybe it is a failing turbo somehow? Since it seems to only happen when the turbo is kicking on?
