I'm so disappointed with this SPEC clutch. My friend bought one at the same time i did, and his car wouldn't go into gear after installing it, they pulled it apart 3 times and it still wouldn't work. They're getting a refund. This is a great clutch, It's this tapping noise that's getting to me.. WTF! I'm gonna pull EVERYTHING apart this time.. this will be my 3rd tranny within a month! I read my Haynes and it said that a Squeal or Rummble when the clutch is released... it could be improper Pedal adjustment, release bearing bind on transmission shaft, Clutch rivets loose (Are rivets the Mounting bolts?) what are clutch rivets? It could also be Clutch Plate Cracked, Fatigued clutch plate torsion springs. Also if the transmission is Noisy in Nuetral it could be the Input shaft bearing worn, Damaged main drive gear bearing, Insufficient Tranny oil, Tranny oil is poor condition, It could Possibly change by variants in engine torque. Change the idle speed and see if the noise disappears.
