i need a little bit of help because after getting the codes from the ecu i get 24, 32, and 41 on my 87 7mgte mt
after doing some research i found that the code 24 is for Intake Air Temp sensor signal and the causes are:
-Intake air temp. sensor circuit
-ECU
BUT the funny part is that i dont have the AFM at all because i am running a HKS VPC. so thats the part i dont understand why i am getting this code.
the second code is 32 is for HAC Sensor signal on the 87-88 7mgte and for the 7mge is air flow meter signal. the causes are
-HAC sensor circuit
-HAC sensor
-ECU
does this mean that the HAC sensor is bad?
and the third code is 41 throttle position sensor signal,
for this one i think i caused by my self, maybe when i removed the throttle position sensor when i took the alternator out and tried to take the tps and the isc sensor to replace the hoses with new ones. Could having moved the tps be causing the code 41?
but theweird part is that according to the tsrm that i have, it says the procedures to clear the ecu codes, i did what the tsrm tells me and i still get the code all over again.
After clearing the codes do i have to drive the code?
-ECU
-HAC sensor circuit
-HAC sensor
-ECU
