I cant remember, they all had to do with the afm. I would go get them again, but i have disconnected the battery so there not there anymore.
I did some testing...
With the Key on, at the tps connector,
Battery Voltage is 11.8
IDL- 4.64 Volts
VTA-0.18
E2-0.02
VC-0.0
With the tps plugged in, at the maft pro blue wire, which is connected to Vta it is at .12-.13 v at idle and floored. And for those who are going to say i need to measure at the ecu, i am measuring at the maft pro, because that is where the signal ends up, so i am testing all the way through. Thanks
IDL- 4.64 Volts
VTA-0.18
E2-0.02
VC-0.0
