Anyone know if I can use the throttle linkage from an GE motor on a GTE motor? I am only talking about the one that mounts over the cam covers. I have the linkage on the turbo throttle body already.
shaeff said:here's what i did
post #3:
http://www.supramania.com/forums/showthread.php?t=1111&highlight=throttle
-shaeff
shaeff said:yep, i've got the big one capped off, but i have my PCV system bypassed, and that pic was taken before i installed a catch can. the large one should go to the two ports on the valve covers, one on the TB, and to the accordian pipe. the small one, i believe goes to the heater valve. (which i also removed. )
-shaeff
j_magers said:so for your catch can you have two lines coming off the cam covers and one from the accordian hose to the can correct.
shaeff said:i bet it'd be easier to just get an N/A throttle cable and do what i did. plus, you get the benefits of NO linkage, and a better pedal feel!
-shaeff
