Throttle Body's?
Status
Not open for further replies.
empera
Authorized Vendor
Philly.
ok cool, cause i can get a 65mm mustang/explorer tb for cheap and was wondering if it'd be wise to use.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The biggest question is can you get the TPS to talk to the ECU...stocK ECU = challenging...stand alone = much easier. Plus, what is the bolt pattern for the intake manifold and does it match.
If you are using a FFM...it should be fine (assuming the bolt patter matches). On a stock manifold you will need some sort of an adapter and you will need to port the flange opening for the TB for the larger diameter...it's made for the stock TB diameter.
empera
Authorized Vendor
Philly.
im using a FFIM, which is currently being built...as for the TPS thats going to be tricky, any suggestions with stock ecu (piggyback)
empera
Authorized Vendor
Philly.
wow, nice work jimi, few questions...was size were the threads on that EGT probe bung? Also would u be able to make another TPS adapter that u could sell me?
Thanks.
jimi87-t
1,126
4
Colorado Springs
Thanks empera, the threads are 1/8" NPT (autometer EGT), bought the thread tap at ACE hardware. With the TPS adapter, I would have to have the same type of TB you are going to use on hand, plus it's really easy to make :icon_bigg .
Status
