Thoughts on your auto to 5 speed swap?
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
theKnifeArtist;964223 said:
i think you might be wrong sir. more load, means more hot expanding gasses. These of which spool up the tubine, inturn making boost build. As far as I know,the automatic might be worse in a sense that the torque convertor is slipping all the time, reducing load. That's why i thought that the manual read two different boost levels, for the auto and the manual. 6.0psi and 7.5psi
no? :dunno:
I acknowledged I was wrong just not directly …. Nick gave him the technically correct answer to his question. My response was incorrect but when you look at most real drag cars they are autos b/c why? The shift points are more precise and quicker meaning they don’t loose a 10th of second due to shifting so they let off of the load and get back on quicker meaning they build boost quicker than the manual trannys for the most part that was my logic. But that was not the question :)
jdub
Feb 10, 2006
10,730
Valley of the Sun
Keep something else in mind...load on an Auto may not be as great initally, but you can build boost with your foot on the brake up to TC stall. Also, boost does not fall off during shifts...it continues to build...no BOV pssssttt sound like you hear on a manual shift.
